  #28 (permalink)
Old 07-23-2005, 12:54 AM
Keithc8 Keithc8 is offline
Dave I think it was Allen Halbert that did his this way that rob was telling me about. Did you do yours or did Rob have it done. I know I am going to need mine done this way if it will still clear the linkage on the 2x4. I was pulling about 1000cfms at the top of the pull through both carburetors together. I see a lot of small air cleaners on these cars and I know that it is choking it down.
I will do some checking on the cam gear stuff. Comp Cams does have a new polymer type gear out but may not have one for the FE. I also know that we use a steel gear on the hydraulic rollers and they also do some of the solid roller camshafts with this core. I will see if the steel gear will work on the solid roller cores as well. I know that a lot of the distributor gears are just stuck on the distributors where the hole is drilled in the gear. This is not always the location it needs to be. We have found some on in the wrong place and this caused premature wear. Keith
Keith C
