Thread: Spark Plug Gap
Old 07-23-2005, 05:39 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
There isn't really one right stock answer, for optimnum results you need to experiment some.
Same goes even for spark plug heat range. As you start modifying the engine and using different ignition components there's no answer in a book.
BUT, with a healthy ignition system, as a base starting point, if you have less than 10.5:1 compression, try .050 to .060.
Between 10.5 and 13:1 try .040 to .050.
If your ignition isn't so powerful you will need to go with a slightly smaller gap.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
