Old 07-25-2005, 02:16 PM
Snak Iyz Snak Iyz is offline
Cobra Make, Engine: Former owner of BDR 127......
Default MM
I had a Hidden Audio system installed in #127. It worked via a remote. Everything installed in the trunk (including 10 disc changer) with a small head unit with the RF right under the dash. I had to 4 inch speakers pointing down installed behind the dash and two 6x9's with speaker casing firing through the back wall carpet, in between the seats.
No one could ever tell there was a sound system installed from the outside. As for the trunk, you would have had to stick your whole head in to really even see it.
I will say that the components are not the best, but given the open cockpit and wind noise, it worked well for what I needed it for (acceleration tunes....). You should be able to find them and a dealer location near you online.
Good luck!
- Paul
- Paul
Most of us can read the writing on the wall; we just assume it's addressed to someone else.
