Old 07-25-2005, 02:44 PM
Three Peaks Three Peaks is offline
Well, I figured it out. I actually drew some lines on paper to replicate the deck lid edge and cut out some craft paper shaped like the hinge and another piece like the deck lid. Took some tape and attached to lid/hinge in different ways and used a push pin as a pivot point.
Seems like the magic number is that the hinge pivot point needs to be 2 1/2" forward of the lip of the deck lid opening. This makes the deck lid clear before the swing of the hinge makes it contact the upper edge of the body.
Not only that, but by carefully cutting off the end brakets with the pivot pieces on them, I can weld them onto the bird cage support at a 30 degree angle so they will be pretty much hidden and they will work perfectly.
I love it when a plan comes together! -Bob
