This just gives you a great opportunity to buy a stroker kit and build a little more HP than you might have with the stock 351W. You just have to be careful matching up your pistons and rods to match your deck height. Other than that, it shouldn't be a problem and the 69 blocks are probably the strongest of the 351 Windsor units.
You'll also have to be careful what intake you use, but these are readily available as long as you specify the year of your block.
