Old 07-27-2005, 08:18 AM
Three Peaks Three Peaks is offline
Default Scratch builders- steering column?
What is the best steering column for my set up?
Obviously, I'm not trying to build a completely accurate replica of an original, including the fact I'm using a small block. So, which steering column would be best for my purposes?
I've seen reference to the Volkswagen units, as well as Ididit columns and a couple others. What are you guys using and what are the pros and cons?
Also, what steering wheel will work with these units and how are they attached?
Thanks, Bob
