Old 07-31-2005, 10:20 AM
Have it pressure tested. Put a pressure tester where the radiator cap was and often with a blown head gasket the pressure will increase quickly and go well above the rating of the pressure cap. Often you can see the needle "bouncing" as it moves up due to the pulses of the engine pressurizing the system.
Your symptoms sure do support your blown head gasket theory all right!
