Old 08-01-2005, 03:41 AM
jess jess is offline
Cobra Make, Engine: classic revival 302w
hi guys
apparently the small spring only works when the wheel is about to leave the ground or when it's about to make contact with the road surface after lift off, you would need to drive the car preety hard for this to occur also found the avo shocks pretty hard once you get past the 3rd adjuster this is just an observation my car is nowhere near compleate the suspension has to work otherwise all the impact will be taken up by the rims and the car will tend to oversteer and not handle the way it should yet if anybody out there has the ride height specs ie: centre of hub to top lip of guard and some wheel alignment specs for the classic revival this would save a lot of time unfortunatly every time you chance the ride heights you must get an alignment front +rear so its not something you want to do to often
jess
