Old 08-02-2005, 10:09 PM
Dave Bermani Dave Bermani is offline
Club Cobra Member
Cobra Make, Engine: Shell Valley. 427W , SB-100
Default Shell Valley SB100 For Sale
Shell Valley Cobra Replica For Sale. SB100 REGISTERED. $32,000 ($25,00 w/o engine). Shell Valley kit with 427W Ford custom built by Pro Street Terrorist, La Habra, CA. Comp roller cam, Comp roller rockers, Scat crank, forged pistons, custom ported RPM Performer heads, 11.5:1 CR, steel bellhousing, and more! Approx 550hp. Ford 9" rear rebuilt by Currie with 3.70 gears and T.S.D. ("posi"). Tremec TKO 5-speed. MSD 6AL ignition and Pro-Billet distributor. Speed Demon 850 carb, Team III wheels, custom stainless steel dash, chrome side pipes, and lots of detail work. AutoMeter gauges with 180 reverse speedo. This car is ready for finishing touches, final bodywork and paint...the color of your choice! There are less than 1,000 miles on it...essentially it's new.
BEST OF ALL: It's registered in California under SB100. That means it's exempt from smog tests! Consider this: only 500 SB100 numbers will be available Jan 1, 2006. There are a lot of guys who will be in line when the DMV opens… If you're thinking about building a Cobra replica, add up what it will cost you for the kit, shipping, engine, tranny, wheels, tires, and accessories. Add the hassle of registration and you'll see that this car is a deal. You can drive this car while you finish off a few things. Be aware that this car is loud, hot, and unruly. But it's a blast to drive and you'll see smiles everywhere you drive it.
The car is located in Brea, CA.
Dave 310-488-7536.
