Thread: Ignore (EOM)
  #4392 (permalink)
Old 08-03-2005, 06:04 AM
392cobra's Avatar
392cobra 392cobra is offline
6th Generation Texan
trularin,
It sounds like you have worn plastic shifter rod bushings and/or slop between the clip and shifter arm.
Hurst (Mr. Gasket) makes a replacement kit that uses steel bushings,$6.99.With this kit and AN washers of the correct thickness between the clip & arm the rods have zero slop.
Very solid feel.I use this kit on my Hurst in a '67 RS/SS 396 Camaro.
Below is from the Jegs catalog.
Mr. Gasket Shifter Bushings
View larger image
Shifter Bushing And Clip Kit
Heat treated steel bushings provide positive shifting and a better ''feel''. Designed to replace original nylon bushings. Includes 6 bushings and 6 clips. Fits most Hurst shifters.
For a complete list of Mr. Gasket Shifter Bushings, click here.
720-11 Shifter Bushing and Clip Kit | View Product $6.99
