Old 08-05-2005, 06:32 AM
Three Peaks Three Peaks is offline
Or you can get some adaptors that bolt onto your existing hubs and have the pin drive pins, hub, and knock-off. Substantially cheaper, but not as authentic as a Jag or AMP rear end. You could also use the Ford T-bird IRS from 88-95 Super Coupe and use the adaptors.
Is your existing rear end an IRS or straight tube rear end (live axle)?
