Old 08-08-2005, 06:13 AM
dlampe's Avatar
dlampe dlampe is offline
Rick, I set the timing on the dyno at 34 deg. That was the sweet spot. We also did alot of work to get the A/F ratio right. I don't know how the cam is setup. Is there a way to check that? I am running an aluminum flywheel as well. I really wish I knew how much compression I was running. The blue Thunder heads are 66-68cc's stock. We had to free up the intakes and shave the dome on the pistons from 9 to 5cc's. I only run race gas, 110 leaded throught the motor now but was thinking about a 50/50 blend. I feel like I have the right peices and it should be doing better.
High Maintenance Racing Team
Run & Gun 2003 - 2013
