Old 08-08-2005, 02:51 PM
JustOne JustOne is offline
Cobra Make, Engine: Unique FIA, 425 Windsor
You can do if you spin the motor to 7500 and have a 12.5:1 motor, but it will not be streetable on pump gas. Going from 9:1 to 10.5:1 is about 15 - 20 HP. You can also go biger cam, but the heads just don't flow enough to justify the drivability. I would go with the AFR (you would have to change pistons) or the smaller Canfields or Brodix for this combo.
