Thread: No Clutch
  #34 (permalink)
Old 08-08-2005, 06:46 PM
tfarhood tfarhood is offline
Cobra Make, Engine: Backdraft #101, 342 stroker
The slave cylinder with the bleeder valve facing up is S1031 from New Generation Clutch systems. It is probably the same number on most aftermarket OEM spec slaves. I got mine from a local parts supplier comparable to NAPA. The part number was either one number higher or lower from the number of the 1990ish Mazda B2200 pick-up (bleeder valve pointing down).
tfarhood
