Old 08-09-2005, 02:27 PM
FeWedge FeWedge is offline
Cobra Make, Engine: Kirkham 496 Aluminum Tunnel Port 687 hp 653 trq
Check the angle of the rod when you press the brake pedal. The clutch and brake pedal have different mounting points where the clevis pins attach. If you have the brake pedal on the clutch the pivot sit's about a 1/4'" too high and it throw's the pivot angle off. I had the same problem with mine.
Rob
