Old 08-10-2005, 06:33 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Chris,
I don't know how hard it may be to get to your relay, but you can change it or use the above method. Also make sure that you don't have a ground or loss of power to the relay coil because of a bad connection. Last of all and most hopefully not the problem could be in the dimmer switch itself. I had that happen in one of my regular cars and the dimmer switch was causing it.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
