				Relay
		Chris,
 I had the exact same problem. I found the relay to be bad. It is under the dash to the right of the steering column. It is just attached to a metal plate and easy to remove without any tools. To find it just click the headlight switch and you will hear the relay. What I did to repair is removed the relay and removed the wiring to the relay and reattached the wiring. Reinstalled and their has been no other problems.
Hope that works,
Regards
Mike
