Old 08-12-2005, 07:55 AM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
I would highly recommend a thermostat if you are going to be running an oil cooler.
Several threads on the subject with manufacurers mentioned on the forum.
Trick here is to get the oil up to the proper temp. The oil coolers definately seem to work and, in most cases, too well and don't allow the oil to reach proper temp.
DonC
