Old 08-12-2005, 02:35 PM
zipzip's Avatar
zipzip zipzip is offline
Cobra Make, Engine: Midstates work in progress, personally built 302
Correct, in to the heater from the water pump, out to the intake manifold water jacket. The reason is that even though there is flow at the manifold, you are "downstream" of the pump. By peeling the water off at the pump outlet, you insure a better transfer of fluid through the heater core.
Hope this helps.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
