Old 08-12-2005, 04:57 PM
smash smash is offline
Default Re: U-joint
Originally posted by David Kee
The yoke we sent should be a 1310, it should measure 3 3/16" between the snap ring grooves. This yoke has the smallest u-joint size available because it was the most common.
Yes it is - but how does this help? I need to move forward here.
The original yoke measures 2 7/8" between the snap rings - as the expert here, is that stock for a 25 spline shaft? To be honest, if you can answer that, then I would have expected you to point it out when I ordered.
Is there a solution other than welding a replacement matching UJ on the prop shaft?
