Old 08-13-2005, 06:30 AM
David Kee David Kee is offline
I wanted you to check the new yoke to make sure you had the correct part. I have never had a problem with a 28 x 1310 yoke replacing a 25 spline yoke so this is new to me. The only u-joint size I knew about on a 25 spline yoke is 1310 until now.
If I thought this would not be a direct swap I would of explained any problems in great detail. You called me with a problem and I sent you everything I thought you would need to fix it. The only correct fix for your broken 25 spline mainshaft is a replacement 28 spline mainshaft. The 25 spline mainshafts are defective and should not be used, ever. If you had found another 25 spline mainshaft you would be doing this again.
There are two solutions:
1. Use a conversion u-joint
2. Change the front of the drive shaft to 1310
