Old 08-14-2005, 07:47 PM
RodW RodW is offline
Cobra Make, Engine: BDR Car # 186 & Keith Craft Aluminum 427 Windsor
Same fix here. On my BDR the distance between the license plate light and trunk handle is not enough to clear the plate comfortably without notching the license plate as well as moving the holes higher on the license plate bracket. Notching the top of the plate about ½” allows it to snug up under the license plate light and clear the trunk handle. You also need to bend the ends of the bracket to get the plate to stand straight. I made a template of the plate so I could make the notch as clean as possible. The notch is so slight that you don’t notice the plate is cut. The only thing I forgot to do was to add my name to the long list of those who have already written the factory.
Rod
