Thread: Tripod Lights
Old 02-22-2006, 07:34 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Here are some observations, having been a long time PL700 Tripod /Tri-Bar user....
First... there is no circut breaker on the ERA so please disregard Frank Messina's post, unless you have added a circut breaker to the ERA electrics. Frank makes a good point about the ground. Having both filaments lit at the same time is interesting... however be careful of the amperage draw.... measure it.
Second... the Tripod does have a correct way to install the bulbs and an incorrect way. The tiny reflector, inside the bulb, should be placed ABOVE the filament when you insert the bulb into the lens.
Third... I did have an occasional problem with my headlights and my front direction lights. Recently, with Bob Putnam's help, I found that my frame (which was powder coated) had a sometimes faulty ground connection up in the "X" member of the front suspension. It appears, that over time, the once good ground became only occasionally good. I scraped a penny sized area of the powder coating off of the X member and dabbed it with dielectric grease. That fix has clearly made both of my front head lamps much brighter and consistant. What I did notice before the fix was that one of my low beams was just not as bright as the other, likewise the high beam.... Now they are both quite bright.
Fourth... There are three wires that feed each of the front head lamps (two three wire circuts). These are ususally jointed with rubber coated barrel connectors, with two male ends, up near each side of the top of the radiator. Make sure that these barrel connectors are firm and that the male ends have a good contact. I had my passenger side front headlight occasionally "winking" on and off and this was fixed by checking all three of the barrel connectors. What I did was clean them, and add a bit more crimping to them.
Fifth.... in a bad ground situation or a ground feedback, the headlights will still work and this can put stress on the headlight switch. These Lucas switches (off, on, on) are pretty sturdy, however, part of my fix after working out the poor ground issue was to replace the headlight switch as well. Check the knife connectors on the back of the switch to make sure that they are firmly attached.
Sixth... tripod lenses can become filmed up (dirty) over time (as they are not sealed(even though they do have or should have a rubber boot that fits over the bulb attachment area)), so what I did was to wash them with dish washing detergent (for the electric dish washer the kind that sheets and leaves no spots) and dry them out well. They sparkle now.
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
