Thread: Tripod Lights
Old 02-25-2006, 09:10 AM
REDSC400's Avatar
REDSC400 REDSC400 is offline
Cobra Make, Engine: ERA #375 427 S/C - 428FE - Toploader - 1968 AMX 390 Go Pack 4 Speed - My Daily Driver is a 2004 Crossfire
Send a message via AIM to REDSC400
Originally Posted by CobERA
Art,
I bought halogen replacement bulbs from Bill Tracy and the lighting was better, but still not right.
After reading your post, I pulled the headlamps off again, and sure enough, even though I had properly lined up the "key" on the bulb with the lens, it caused the bulb to be mounted upside down, although not a full 180 degrees.
I got out my Dremel and cut a new slot in the lens, inserted the bulbs with the reflector on the top, then took it out for an evening test drive.
MUCH BETTER! Thanks again for the good info.
I too purchased my latest set of bulbs from Bill Tracy... small world eh? I am glad that little tip worked. A long time friend of mine who has a Morgan told me about it a few years ago at a cruise night. Sometimes (if not always) it is the little details that make the difference.
Once the weather breaks here in Connecticut, I will be out on the roads using those lights! Can't wait. But for now, I am cleaning my tires and wheels. The inside of the rims were filthy (up front) so I cleaned them up with a toothbrush and a slew of rags. About half way thru the job I realized that I should have worn gloves... what a mess...
I guess I should do the dishes...
Art in CT
See My Website at http://www.lithicsnet.com
A car can massage organs which no masseur can reach. It is the one remedy for the disorders of the great sympathetic nervous system. Jean Cocteau 1889-1963, French Author, Filmmaker
