Old 02-26-2006, 11:31 AM
decooney's Avatar
decooney decooney is offline
Default Sidepipe modification done. Fine tuning next.
Hi Dean & All,
Well, after much analysis - I DID IT. The new 3" round ID cores went on yesterday and I cranked it up yesterday for the first time. They are back off now for painting. I went with 20.5" (.5" longer) and cut off my old muffler cans and reused my header-collector, tailpipe tip, and mounting brackets.
Observations and Conclusions:
- Sounds nothing like my original 2.5" ID ERA exhaust pipes. Totally different.
- Much deeper and less crackle sounding; More deep pop, sound pressure.
- At least 25% more air coming out at idle by a quick hand check.
- The new muffler cores weigh about HALF. Those old ones are heavy.
- LOUDER at low frequency exhaust note range (more DB)
- QUIETER at high frequency exhaust note range (less DB, less annoying)
- More noticeable torque response at midrange for sure, a nice suprise.
- I think I need to rejet, checking on this now. Need to measure. 2-3 up?
- To me, Its maybe 20% louder but only at low frequency which is nice.
- Seems easier to talk with a passenger now with mid/high frequency gone.
- Exhaust note/type is more similar to a factory SPF sidepipe than ERA, KMP.
After looking at this muffler setup a bit more all said and done, there is actually some engineering to it; and more than I originally thought. The shorter ID glasspack inside a larger center section creates a chamber expansion-contraction-expansion effect which completely changes the exhaust note; it cuts out almost all of the high frequency note. This is very similar to some expermintation I did with my Harley Fat Boy exhaust a few years back with the exact same type results. Once I get the sidepipes painted up, decide on what carb rejetting is actually required, I'll have a better idea on performance gains. Overall, I'm really glad I had my factory ERA pipes on there for a while first to make a real hands-on comparison. Its fun to try something different. There are about 10 guys around here waiting to hear the results. Pun intended. Can't wait to get them back on again. See Ya.
Duane
