Old 02-27-2006, 06:49 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Default Oil temp????
OK, the temperature of oil has been mentioned a couple of times. What is a good oil temperature range? I have an oil cooler, more for looks than performance, maybe I should by pass it.
I rebuilt a 289 hi po 271 HP many years ago. The factory rod bearings had holes in them, the new ones didn't. I drilled holes in the new bearings to match up with the holes in the rods. I ran the hell out of that engine for years afterwards with no problems. Those little holes certainly add lubrication to the cylinder walls and the cam & lifters.
Wayne
Don't get caught dead, sitting on your seat belt.
