Thread: brake fluid
Old 05-24-2001, 05:52 PM
BT SNAKE's Avatar
BT SNAKE BT SNAKE is offline
Cobra Make, Engine: Midstates Cobra, RFGT40
Question Synthetic Brake Fluid
It seems that silicone brake fluid is taking a bad rap
here . Just where is a good applicable place for the
stuff? It hasn't been on the shelf for twenty years
because its pretty and saves your paint. I have the
stuff in my cobra and it has been in there for 11yrs
No problems. I also have a 34 Ford street rod I
built in 1984. I have it in that as well. Not one time
have I experienced a problem with it. I have little
track time on the cobra, but it has seen its share of
autocross. I also have it in the slave cylinder. As far
as I can tell it has gone beyond the call of duty. I
will continue to use it until something subsantial
comes along and says its really really Bad!!
Hence, no recalls as I know of as yet!
I do bleed the brakes when new pads are installed.
Properly maintained brakes will not acquire moisture.
Brake fluid does not absorb water. when water is present it will mix when agitated but it will then
seperate over time. It causes the same damage in
any other system thats suseptible to moisture.
The stuff has a 500 degree wet boiling point. Unless
you're running Sebring or Le Mans you shouldn't
need more than that. Water in any system boils at
212 degrees. Hygroscopic or not, water should not
get in the system period.If it is then you got a bigger
problem.
BT SNAKE
Hersh
PS. Scott, I think you may have to rap the header thats
under the master cylinder as thats what is causing
the extra heat and the spongy brakes. I believe
you will have the same problem with the Castrol SRF.
