Old 02-28-2006, 12:19 AM
Jac Mac's Avatar
Jac Mac Jac Mac is offline
Cobra Make, Engine: DIY Coupe, F/T ,MkIV.
I assume you tried all the usual tricks. Offset the seal from the rear main cap approx 1/4"( one up-one down), removed the rope pin?,checked the knurl in the crank surface acts to return the oil to the pan( found on reverse rotation- marine cranks), oil gallery or cam bore plugs at rear of block.
