Old 02-28-2006, 10:18 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Clois,
All of the Wilwoods have 1 square seal per piston. I also use a small pointed pick to get them out. With regards to the o-rings on the internal fluid cross-over calipers only, you will have a seal at each joint. If you have one spacer (between the body-halves) you will have 2 o-rings. if you have two spacers you will have three o-rings.
Jason
