Old 02-28-2006, 05:14 PM
jeffko's Avatar
jeffko jeffko is offline
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Jaybar, I would get that header tape off your pipes. I believe you will ruin the ceramic coating.
I am considering making a stainless steel shroud that would maybe match the surrounding engine compartment. Since it is radiant heat you just need to deflect it. Maintaining an adequate air space where air can move through the space is the most important.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
