Old 02-28-2006, 07:45 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Power valves are not sized by fuel flow. The number is where they open in regards to the amount of vacuum. You may want to try a 10.5 power valve because it will open a fraction sooner than the 6.5 you have now.
What did you do in regards to the squirter? Larger squirter? If so, from what to what regarding size? Use a different squirter cam?
What kind of carb do you have? Do you notice any bog or hesitation when driving around?
What was the A/F ratio at full throttle? OK/rich/lean?
Warren
