Just a quick follow up to this thread. Last night I pulled the calipers off again and replaced the pass thru o-rings and the piston square cut o-rings and it was very simple. Here is the procedure I used (someone correct me if I have done anything wrong) after disconnecting the brake line to the caliper and removing the brake pads:
1. Removed the safety wire and removed the 9/16" bolts that mount the calipers to the brackets.
2. Place a 1" piece of wood between the pistons and took my air gun and forced the pistons out of their bores (They only came out about half way).
3. Removed the four Allen Head bolts that joins the two halfs of the calipers and the spacer(s).
4. After seperating the two halfs and spacers of the calipers I then took a pair of pliers to pull each piston the rest of the way out using a twisting motion and being careful not to mark or scratch the pistons.
5. I then removed all four bleed screws on the two halfs of the calipers.
6. Using a can of brake cleaner I cleaned all the parts and wiped with a blue paper shop towel and then cleaned again with the brake cleaner being sure to get into each hole and opening with the pressurized spray. Then I blew each piece dry with the air hose and set aside on a clean shop towel.
7. Remove and replace the passage butyl o-rings (one located in the outside of the caliper and the other is located on the opposite side of the spacer. Next take a pick and remove the 1 3/4" square cut o-rings from the piston bores if the didn't come out during the first cleaning.
8. Using the brake cleaner again clean the piston bores and air dry.
9. Install the NEW square cut o-rings back in the bores. Then place the caliper halfs on a flat sturdy surface. I then took each clean piston and poured a little brake fluid over the piston and installed each back in their bores. I used a FLAT block of wood to force them in once I determined each was going in straight.
10. Re-assemble the caliper halfs and spacers back together and your done. Be sure to safety wire your mounting bolts once you bolt your calipers back on their brackets. Re-bleed your system and your done.
This is a very easy job and I found lots of brake dust in my caliper reserviors, so I believe this is a good practice to do each year or when you change pads.
Clois
"Let's roll"
"Be part of Something Good
