Old 03-01-2006, 03:55 PM
Dennis Kelley Dennis Kelley is offline
Cobra Make, Engine: BDR 302 AFR 165
Yes the carb is a double pumper and has two squirters. I went to get some different power valves and I'm just going to go back to my buddies dyno and try a few different power valves. The air fuel ratio is very good it just seems that the power valve is not opening fast enough. I"ll keep you guys informed after I run the Wide band O2 on the dyno. My typing is poor but I appreciat the help and will try a 8.5 through 10.5 Power valve. The car is in very good tune but I'll also check ever thing. I can use the dyno most of the day saturday.
Later
Dennis
