Thread: Engine stalling
Old 03-02-2006, 04:21 PM
Frank Messina's Avatar
Frank Messina Frank Messina is offline
Cobra Make, Engine: FFR, V8, Manual Trans, Htr, Wipers, Radio Delete
Mt,
I went through this exact same drill when I first finished my car. I'd be driving along and it would just quit. Not a real confidence builder. I'll spare you all the gory details and get right to the punchline. Next time it stops running, pull over, turn the key off immediately, remove the air cleaner and move the throttle a bit to see if you have gas in the bowls. If you do you have a faulty ignition. That's what mine turned out to be. Pulled out the HI-6 box and coil and sent it back to Crane and after testing it out they sent me a new unit. Problem solved. Good Luck.
Frank
