Old 03-04-2006, 01:01 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Brent: Sounds like the V-notch is to match a rod or cap that has a groove across the parting line for squirting oil on the thrust side of the cylinder wall. If your caps or rods aren't grooved, the V-notched inserts are not needed. If they are and your bearings aren't notched, you can always file a notch in them. Just make sure you chamfer the edges.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
