Old 03-06-2006, 12:01 AM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
Originally Posted by Excaliber
I got squirt holes in the top of my rods and still run 80 psi.
The hole on the little end is for oil splash to lubricate the piston pin.
While I've seen rod bearings with "V" notches in the indicated location, the pistons & cylinders also get splash from oil running out from between the rods as the shaft rotates. The larger the gap between the rods (usually .025 max) the more splash.
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
