Thread: Pucker Factor
Old 03-06-2006, 04:22 PM
Yetiman's Avatar
Yetiman Yetiman is offline
Cobra Make, Engine: Arntz/SBC/Jag
They also give a more even mixture across the cylinders. On a single carburetor manifold for a V8, the middle four cylinders are always running a bit richer than the outer four cylinders.
The Webers provide each cylinder a more uniform, typically better atomized mixture which makes more power and allows you to safely run with more compression and/or spark advance.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
