Thread: Dim headlights
Old 03-06-2006, 05:48 PM
jarendall jarendall is offline
Cobra Make, Engine: StreetBeast 66 replica 302 350HP
what type of dimmer setup do you have, I have the VW type system which uses a flip flop type relay, the dimmer switch on the blinker arm is just a ground for the relay, everytime you press it it simply flip flops the relay to a different set of contacts, it uses the standard VW dimmer relay, your system maybe this type if so you may need to check the connections on the relay
PapaJohn
