Old 03-07-2006, 01:56 AM
stephen low's Avatar
stephen low stephen low is offline
Default jag diff and rear brakes
Can any one indicate if the brake lines leading to the rear brakes on a jag diff and caliper set up need to have a flexible line from each caliper back to a T fitting on the chassis.
I was under the initial impression that the diff is solidly mounted to my G-Force chassis or is this not correct. Certainly the lower suspension arms are part of the bracketry associated with the diff, so I would have thought these arms have to be able to experience some flexure!
Can anyone set me in the right direction.
Slowy
slowy
