Thread: Expansion Tank
Old 03-07-2006, 06:30 AM
kidcobra kidcobra is offline
Cobra Make, Engine: building someone elses E&M 1967 427 side oiler
onefastmustang
your set up is the same as mine. I have the tank with the outlet on the driverside. Comes from the Rad into the tank. Works and looks real clean. I had to get two over flow tanks one for each little hose. The over flow one is normal but the other one by the rad hose you can either cap off or run into a over flow tank. If you are running the old Classic cooling system and getting a little WARM on hot summer days this tank will help keep it cool.
If you deside to get one make sure you get the tank is for the driver side.
Matt
I will post pics
