Old 03-07-2006, 08:17 PM
cobraduke cobraduke is offline
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Parts Info for Excalibur
Hello,
I haven't seen this posted elsewhere so thought I'd post it for general info. The Deutsch FF-401 fuel filter is an exact match in size and metal construction to the original located back at the fuel pump. It is available as a stocking item at Auto Zone for about $2.50. Probably other places as well, but that is where I found it. In some of the cross references with other brands they turn out to be same pressure, flow and inlet and outlet size, but are physically larger or smaller and or are not metal.
For anybody interested in my motor problem (laying down at WOT) as reported, then erased in the Big Crash, it turned out to be a bad TPS. (Thanks to High Plains Drifter for giving me the instructions on how to test it and the explanation as to how it was related to the symptom).
I need to know how any of you have figured out a way to mount a front license plate on the bumper or support. The Law down here on the ranch insists that both plates be "properly displayed, boy."
Thanks for any helpful tips.
Mike
