Old 03-07-2006, 09:39 PM
Tim Brewer Tim Brewer is offline
Cobra Make, Engine: Lonestar LS 427, Keith Craft 501,Toploader
Keep trying, they'll come off. Man, if your pipes are stainless, I would or have someone polish those things. Try (after removing all the bolts) spraying like PB Blaster around the joints. Let that sit over night, use a propane or mapp gas torch on the larger diameter pipes and then try carefully beating with a rubber hammer. Don't use any type of high temp paint on your pipes, it will just come off and you'll have to start all over again. If you don't the polished look,(and it looks great!) get your pipes cerramic coated. Most powder coat places can do that.
Good luck,
Tim
" It ain't no big deal"
