Old 03-16-2006, 03:21 AM
Ant Ant is offline
Default Shifter lever offset modifications
My Cobra with Jerico five speed and Long shifter, the gear lever is way over to the left of the transmission tunnel, so what I am trying to do is get it over towards the middle as much as practical, before it comes through the floor. In order to do this I thought about bolting a 2" wide spacer block of aluminium on to the shifter to space the lever across, but this may put a twisting force leverage on the mechanism as the gear lever I will have to make will be bent a bit like a Cobra 427 shifter, this may be bad for shifting etc. I guess I should just build it and see if it works ok, but once holes are made etc its all work to change if not ok.
What I am considering is if you gear a force out from the operating center, instead of going up, down and across, the offset tends to add a circular twisting force into the equation?
A J. Newton
The 1960's rocked!
