Old 03-16-2006, 06:33 AM
jdean's Avatar
jdean jdean is offline
Unless you plan to drive on the highway a lot, then I would stick with the C4. Of course overdrive will drop RPM on highway, and save some gas. C4 in stock form should be stronger than a stock AOD, but you will not have a ton of power anyway. Also, the AODE has stronger parts in it than the older AOD.
6th generation Texan....
