Old 03-16-2006, 10:41 PM
Rick Parker's Avatar
The heads have the coolant outlet/inlet on each end because they can be used on either side if the engine.
What is the rear on one side would become the front on the other side etc,etc.
The way the water pump circulates the coolant is to pull coolant from the bottom of the radiator after it has been cooled. Then force it under low pressure through the two inlets at the front of the block through the timing chain housing behind the water pump, into the block, around the cylinders, upwards through the deck surface, into each cylinder head and then forward out the front of the head into the manifold crossover and then finallly out through the thermostat area. The manifold has areas that could be modified for a cross over hose at the rear but I am not sure if it would serve any purpose.
Rick
