Old 03-16-2006, 11:14 PM
Carnut427 Carnut427 is offline
Cobra Make, Engine: ERA 427 w/496 Side Oiler, roller, dual quads
From my experience, the cam manufacturers usually set the cams up so they'll fit. From my experience, the time when things get tight on an FE is on the intake, as the intake is opening faster than the piston is going down. I've only run Comp cams, and it appears they design the cam so that it'll have enough clearance. You should definitely check both intake & exhaust valve-to-piston clearance whenever you change a cam, but from what I've seen you won't have a problem. I haven't seen an exhaust valve come anywhere near the piston to bother actually measuring the clay. My current cam has a .675 lift (solid roller).
Dan
Do you know why they call it "PMS"? Because "Mad Cow Disease" was taken. --Unknown, presumed deceased
