Old 03-17-2006, 04:40 AM
stephen low's Avatar
stephen low stephen low is offline
Andrew
Thanks but don't bother, I drilled a hole in the metal work and fitted the hbrake cable. Clevis pin is to caliper, adjustment to rear of hbrake.
If I were to cut off one end of the inner cable, turn it around and recrimp I would then not be able to remove the cable assembly at all without cutting off and end again.
Will just have to figure out how to get to adjustment with the seat in place some time down the track.
But i do want to improve the hbrake rear swivel arrangement, perhaps along the lines you guys have discussed.
slowy
