Old 03-17-2006, 08:46 AM
mj_duell mj_duell is offline
Send a message via AIM to mj_duell
Originally Posted by CJ428CJ
I think Mickmate is right. FE pumps are easily capable of generating 100 PSI or more. The pressure is regulated by a pressure relief spring in the oil pump. For a typical high volume oil pump for a 428, that spring is set to open at about 75 PSI. If the bypass valve and/or spring stuck, the pressure could shoot way up. I'd change the oil pump for sure.
Chris
I Agree. I've had it happen to my 428 and changing the pump worked.
--Mike / Turn Ten Racing, Inc.
