Old 03-17-2006, 08:33 PM
Tongue Pirate's Avatar
Tongue Pirate Tongue Pirate is offline
Sounds like we have the same guage. If so the correct fitting for the manifold should be taperd in the bottom as to seal the temp sensor between it & the top nut. If you are getting the top nut to bottom out & there is still slop you have the wrong bottom fitting. If the top nut is tight & there is no slop yet it is not sealing up it is possible that your sensor could be bottoming out before the nut can get 100% tight. If you look here you can see my sensor & manifold fitting. It has a 3/8" pipe thread into the manifold.
Hyde D. Baker
