Thread: Fuel Pressure
Old 03-19-2006, 04:35 AM
strictlypersonl strictlypersonl is offline
Mike,
If the fuel continues to trickle while the pressure goes to zero, then the problem is a bad float needle valve. If the valve were OK, the pressure would stay up for a while (assuming you aren't using a return line to the tank). Since it's probably new, I would just suspect some dirt in there. With the valve constantly leaking, you're also going to run rich all the time.
I don't have the Holley spec sheet here, but 7-8 psi fuel pressure seems to be on the high side.
